[GRASSLIST:8584] problems creating maps using r.le.pixel
Andrew.Haywood at poyry.com.au Andrew.Haywood at poyry.com.au
Tue Oct 11 23:27:43 EDT 2005
Dear List,
I am having some problems using r.le.pixel on some sattelite imagery
(raster called RR_2m.1). The raster I am analysing has ns and ew
resolution of 2m and has 15030 rows and 4975 columns.  I have run
r.le.setup and created the sampling units I want to sample (20*20 pixels
starting in the top left hand corner). I then run the following command
r.le.pixel map=RR_2m.1 sam=u att=b1,b2,b3,b4 te2=t5 te1=m7
r.le.pixel runs and completes successfully but does not create any maps!
Am I doing something wrong?
In the directory "r.le.out"  two files are created b1-4.out and t1-5.out.
These files contain the information I want to put into a new map with
resolution 40m by 40m (or 20pixels by 20 pixels). How can I convert these
flatfiles into maps? In particularly I would like to create 9 new maps b1
b2 b3 b4 b5 t1 t2 t3 t4 t5. Any suggestions how I can script out these
flatfiles into maps would be greatly appreciated.
regards
Andy
Andrew Haywood
Consultant
Jaakko Pöyry Consulting
Level 5, 437 St Kilda Road
Melbourne VIC 3004
Tel +61 3 9867 2700
Fax +61 3 9867 2744
andrew.haywood at poyry.com.au
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20051012/68592253/attachment.html
