[GRASSLIST:8641] v.to.rast with line layers
Miha Staut
mihastaut at yahoo.co.uk
Fri Oct 14 17:10:31 EDT 2005
Hi all!
I can't seem to find the way to rasterize a simple roads (line) vector layer. I
tried with points and areas and both worked, but lines did not. A peculiar
thing is that if I try to digitize a line vector and rasterize it, it works,
but with the "roads" vector layer I always get a blank raster. I did:
psql posts
posts=# \d roads
Tabela "public.roads"
Stolpec | Tip | Modifikatorji
cat | integer |
length | double precision |
cod | double precision |
gavprimary | double precision |
geometry_s | character varying(15) |
link_name | character varying(30) |
id1 | double precision |
type | character varying(50) |
limits | integer |
Indeksi:
"roads_cat" unikaten, btree (cat)
psql=# \q
GRASS 6.1.cvs (master):~ > v.to.rast in=roads out=roads use=attr col=limits
I also tried:
v.to.rast in=roads out=roads use=cat
v.to.rast in=roads out=roads use=val val=1
without success.
I even tried to copy the vector and export it in ascii and reimport it with the
same result.
I have maybe a month old cvs.
Suggestions are welcome.
Miha Staut
___________________________________________________________
To help you stay safe and secure online, we've developed the all new Yahoo! Security Centre. http://uk.security.yahoo.com
