[GRASSLIST:8672] Re: compiling grass 6.0.1 CVS, 2nd
Stephan Holl holl at gdf-hannover.de
Tue Oct 18 09:25:11 EDT 2005
Hello Manuel,
On Tue, 18 Oct 2005 15:06:19 +0200 Manuel Seeger <seeger at uni-trier.de>
wrote:
> Thank you, Stephan
> next problem: configure continues and stops with:
> ***Unable to locate External PROJ.4 includes...
> y searched for them, but didnt get them.
I am again not aware about the status of proj in suse. GDF Hannover
provides rpm-packages for Suse 9.3[1]. Perhaps you might give them a
try. If you try please let us know and we will put a note that the
packages also work on suse 10.
If it does not work, you will most likely build your own package from
source. The spec.files provieded at [1] can be a starting-point.
Best
	Stephan
[1] http://www.gdf-hannover.de/software
[2] http://proj.maptools.org/
> can you help again?
> Manuel Seeger schrieb:
> > Hello all,
> > finally, I installed a Linux computer...
> > with SuSe Linux 10.0.
> > I wanted to compile grass 6.0.1 CVS, but now y dont get over the
> > configure stadium.
> > it stops with the
> > error: unable to locate yacc
> > how can I go on?
> > thanx
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office      -     Mengendamm 16d      -     D-30177 Hannover
Internet: www.gdf-hannover.de      -      Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507       -        Fax: ++49-(0)511.39088508
