[GRASSLIST:8689] Import geodetic points
Ulrich Leopold
uleopold at science.uva.nl
Wed Oct 19 05:52:00 EDT 2005
Dear list,
what is the correct geodetic format GRASS can import. I am trying to import
the following text file:
cat long lat loc
1 5:46:01E 49:48:33N PERLE
2 5:49:10E 49:47:39N ROODT_REDANGE
3 5:50:32E 49:51:35N ARSDORF
4 5:50:50E 50:00:33N SCHIMPACH
5 5:52:28E 49:35:56N CLEMENCY
6 5:52:53E 49:45:48N REDANGE_ATTERT
7 5:54:04E 49:30:44N OBERKORN
8 5:55:36E 50:03:38N WINCRANGE
------------snip-------------------------------
with the following COMMAND:
> tail +2 georef_man.txt | v.in.ascii fs='\t' out=precip x=2 y=3 cat=1 \
columns='cat int, x double, y double, label varchar(20)'
I get the following ERROR message:
Maximum input row length: 40
Maximum number of columns: 4
Minimum number of columns: 4
ERROR: x column is not of number type
Apparently, the geographical coordinates are in the wrong format and the
column specification is probably also wrong (columns= x double, ...).
Which format do I have to use for degrees, minutes and seconds? And how can I
specify that in the columns option? (x long, y lat ??)
Thanks a lot,
Ulrich
