[GRASSLIST:8693] Re: [GRASS5] Re: Re: GRASS, gdal and mapserver
Markus Neteler
neteler at itc.it
Wed Oct 19 10:30:03 EDT 2005
> > On 10/13/05, Francisco Alonso <alonsarp at um.es> wrote:
> > > El Viernes, 14 de Octubre de 2005 10:25, Radim Blazek escribió:
> > > > On 10/12/05, Francisco Alonso <alonsarp at um.es> wrote:
> > > > > # ogrinfo
> > > > > /var/www/grass5_mapserver/spearfish60/PERMANENT/vector/streams/head
> > > > > Warning 1: GRASS warning: GISBASE enviroment variable was not set, using:
> > > > > /usr/local/grass-6.0.1
> > > > > ogrinfo: relocation error: /usr/local/lib/gdalplugins/ogr_GRASS.so:
> > > > > undefined symbol: Vect_set_fatal_error
I have found the same error here. There is simply a bug in the
new plugin as it isn't linked to the vector libs (oversight
in the configure[.in] of the new plugin).
I have submitted patches to Frank and Radim.
Markus
