[GRASSLIST:8704] Re: Import geodetic points
Markus Neteler
neteler at itc.it
Thu Oct 20 04:19:01 EDT 2005
Hamish wrote:
>>what is the correct geodetic format GRASS can import. I am trying to
>>import the following text file:
>>cat long lat loc
>>1 5:46:01E 49:48:33N PERLE
>>------------snip-------------------------------
>>with the following COMMAND:
>>>tail +2 georef_man.txt | v.in.ascii fs='\t' out=precip x=2 y=3 cat=1 \
>>columns='cat int, x double, y double, label varchar(20)'
>>I get the following ERROR message:
>>Maximum input row length: 40
>>Maximum number of columns: 4
>>Minimum number of columns: 4
>>ERROR: x column is not of number type
>>Apparently, the geographical coordinates are in the wrong format and
>>the column specification is probably also wrong (columns= x double,
>>Which format do I have to use for degrees, minutes and seconds? And
>>how can I specify that in the columns option? (x long, y lat ??)
>v.in.ascii will not (currently) read ddd:mm:ss format coordinates. It
>should be using the G_scan_easting() and G_scan_northing() library
>functions to convert these into floating point numbers but this hasn't
>been done yet.
Are you sure, Hamish? I thought that I had implemented that (GRASS 6.1-CVS)
cd vector/v.in.ascii/
grep G_scan_easting *
points.c: if (G_scan_easting ( coorbuf, &easting,
window.proj) ){
points.c: G_scan_easting ( tokens[xcol], &x, window.proj);
>So you need to convert 5:46:01E into +5.000212963 and
>import that way.
This should be no longer needed.
2005-10-04 22:36 markus
* description.html, in.c, local_proto.h, points.c: DMS LatLong
import functional now
Please report if it *still* doesn't work.
Markus
