[GRASSLIST:8747] Re: gmtg
ivan marchesini
marchesini at unipg.it
Mon Oct 24 18:45:28 EDT 2005
Dear Jaime...
I have succesfully installed r.gmtg ... I think... the command is now
present at the grass prompt...
and also modflow96... (also if I have tried to run the ./test 1 1 but I
have stopped because it takes a long time to run...)
Later I have created a DATAGRASS54 and copied inside the exercise1
location...
I can correcly seen the maps in the PERMANENT mapset and I can plot
them...
later I have done
______________________
cd exercise1
tar -xvf read_mflw.tar
g77 rheads.f -o rheads
g77 rddown.f -o rddown
later I have read the first part of the tutorial and I have seen that
the results of the first simulation are already present in the
location...
so I have tried to run the transient simulation using:
____________________________________________________________________
r.gmtg simulation=0 units=4 layers=1 aqtype=1 stress=2 length=240,120
steps=12,6 tsmult=1,1 region=boundaries heads=hd.lay1.stp1.tst1
K=H.conductivity Sy=Sy bottom=bottom recharge=rch.1,rch.2
wells=wells,cst.flux drawdownin=ddtr headsin=hdtr
the problem is that I don't obtain the maps
ddtr.lay1.etc
hdtr.lay1.etc
and the standard output of the command is:
Processing BAS file
96%
Processing BCF file
96%
Processing RCH file
96%
Processing WEL file
Running MODFLOW
GRASS:~ > Importing DRAWDOWN
and after this there aren't active processes in my pc!!!
can you help me to understand what is happening???
it is a simple problem??? I have done a stupid question??
thank you very much!!!!
ivan
Il giorno lun, 24-10-2005 alle 10:47 -0500, Jaime Carrera ha scritto:
> Dear Ivan,
> Yes, you can use the tutorial and the files that are
> on the GMTG web page. Keep in mind that the MODFLOW
> version available on this web-page is required as I
> did a slight change to the code so it can run with
> GMTG.
> I'll be glad to know how it worked.
> Cheers,
> Jaime
> --- ivan marchesini <marchesini at unipg.it> escribió:
> > Dear all, dear Jaime,
> > I have finaly enougth time for starting to try the
> > use of modflow using
> > the grass module...
> > looking at the mailing list I have seen there have
> > been some problems
> > with the installation reported by other users...
> > could you say if the problem are now solved???
> > can I use the tutorial at the web page
> http://grass.gdf-hannover.de/twiki/bin/view/GRASS/JaimeCarrera
> > thank you very much for your answer!!!
> > Ivan
> > Ivan Marchesini
> > Department of Civil and Environmental Engineering
> > University of Perugia
> > Via G. Duranti 93/a
> > 06125
> > Perugia (Italy)
> > e-mail: marchesini at unipg.it
> > ivan.marchesini at gmail.com
> > tel: +39(0)755853760
> > fax: +39(0)755853756
> Correo Yahoo!
> Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
> Regístrate ya - http://correo.espanol.yahoo.com/
Ivan Marchesini
Via G. Duranti 93/a
06125
Perugia (Italy)
