[GRASSLIST:8824] Re: v.in.ascii + v.to.rast help
Giacomo Bertoldi
giacomo.bertoldi at ing.unitn.it
Mon Oct 31 11:50:28 EST 2005
Thanks for your help.
The importation command works:
v.in.ascii in=/Users/giacomo/John/Kustas/LES/200july2_1.dat
out=sm200july2 x=1 y=2 columns='UTMEast double, UTMNorth double,
LandUse int, Soil_textr int, Soil_moist double, NDVI double' fs=' '
db.describe -c table=sm200july2
ncols:7
Column 1: cat
Column 2: UTMEast
Column 3: UTMNorth
Column 4: LandUse
Column 5: Soil_textr
Column 6: Soil_moist
Column 7: NDVI
Then I have still problems to make a raster at 200m resolution (sites
are on a regular grid) I tried:
v.to.rast input=sm200july2 output=sm200july2_lu use=attr column=LandUse
rows=4096
or:
v.to.rast in=sm200july2 out=sm200july2_lu col=LandUse
But I do have the error:
"Key column type is not integer"
Thanks, Giacomo
On 27 Oct 2005, at 21:11, Hamish wrote:
>> Hi all, i would like to import in GRASS the following ascii file with
>> v.in.ascii and then convert it with v.to.rast
>> What is the correct syntax of the commands in order to import
>> correctly?
>> UTMEast UTMNorth LandUse Soil texture Soil moisture NDVI
>> 582200. 3.93700e+006 10 4 0.284077 0.522864
>> 582200. 3.93680e+006 10 3 0.288844 0.468007
>> 582200. 3.93660e+006 10 3 0.283344 0.335329
>> 582200. 3.93640e+006 10 4 0.275129 0.295116
>> 582200. 3.93620e+006 6 3 0.253937 0.273246
>> 582200. 3.93600e+006 4 3 0.261889 0.270069
>> 582200. 3.93580e+006 10 4 0.302256 0.130456
>> 582200. 3.93560e+006 10 3 0.291805 0.208106
>> 582200. 3.93540e+006 10 3 0.287783 0.310229
>> 582200. 3.93520e+006 10 3 0.283377 0.224217
>> 582200. 3.93500e+006 6 3 0.271582 0.164878
>> 582200. 3.93480e+006 6 4 0.311506 0.174538
> GRASS 6.0 you have to get rid of the first line, GRASS 6.1 you can use
> "skip=1" to save the column titles to the map history, or start the
> line with a '#' to skip past it.
> v.in.ascii in=your_points.txt out=new_map x=1 y=2 skip=1 \
> columns='UTMEast double, UTMNorth double, LandUse int, Soil_textr
> "columns" names are optional, but useful. DBF DB only lets you set
> column names as 10 characters long, no spaces. Each point will be
> assigned its own category.
> query with d.what.vect to check
> Hamish
Giacomo Bertoldi, Ph.D.
Dept. of Civil and Environmental Engineering
Duke University
E-MAIL: bertoldi at duke.edu
