[GRASSLIST:8160] Re:v.in.ascii problem
Michele michele.rocc at libero.it
Fri Sep 2 06:28:42 EDT 2005
> I get this message even when trying to import an ascii file, as described
> in the manual?
> v.in.ascii input=/Users/Stefania/Almere/PERMANENT/points3d.txt
> output=mypoints3d1 format=point fs=| 'columns=x double, y double, z double,
> label_cz varchar(20), label_en varchar(20)' x=1 y=2 z=3 cat=0 -z
> Maximum input row length: 101
> Maximum number of columns: 5
> Minimum number of columns: 0
> x column number > minimum last column number
> Yours,
> stefania
Hi Stefania,
be sure to give one and only one "carriage return" at the end of last row in your data file, this may solve the problem.
Michele.
____________________________________________________________
Libero Flat, sempre a 4 Mega a 19,95 euro al mese!
Abbonati subito su http://www.libero.it
