[GRASSLIST:8188] Re: Grass6.0.1 Binaries for Mandrake 10.0
Alejandro Hinojosa
alhinc at cicese.mx
Tue Sep 6 17:33:04 EDT 2005
Dear list,
Since nobody came to the rescue but Otto , let me tell you how i fixed
using the binary distribution intended for Mandrake 10.1 in version 10.0
This is to solve the dependencies of the distribution rpms. Otto indirectly
suggested to migrate to 10.1, but sometimes it's to much hassle to
backup everything before migrating.
I followed the installation sequence defined in the readme of the
distribution site for Mandrake
http://www.gdf-hannover.de/media.php?id=1&lg=en
then when the dependencies started to appear i went
to http://rpm.pbone.net and searched for the libraries requested,
download them and installed manually with root privileges with rpm
-ivh package.rpm.
At the end, I got grass60 to run. I hope I don't get into furture problems
for running on version 10.0.
My first surprise, besides the interface, is that it will not see my old
vectors from 5.4.
Alejandro
At 11:22 PM 9/5/2005 +0200, you wrote:
>On Mon, 5 Sep 2005, Alejandro Hinojosa wrote:
>>Dear list,
>Dear Alejandro,
>>I have Mandrake 10.0 running on my pc box and downloaded the rpm binaries
>>for grass 6.0.1 from gdf-hannover.
>>Will this version run under Mandrake 10.0?
>>I started following the installation order from the readme,
>>doing manually with rpm -i -v package.rpm . The first package
>>(proj-4) installed without trouble, but didn't know where it was
>>installed. For the second package (gdal-1.3.0-2mdk10.1.i586.rpm) the
>>installation aborted with errors:
>>Failed dependecies
>>libstdc++.so.6 is needed by gdal-1.3.02mdk10.1
>>under /usr/lib there is a libstdc++.so.5 but no libstdc++.so.6,
>>Any clues, directions? Do I need the Mandake 10.1 or a symbolic link
>>from libstdc++.so.6 to libstdc++.so.5 will do.
>you can try a symbolic link, but I don't think this will work. The
>packages are compiled on a mandrake 10.1 and unfortunately not build for
>Mandake 10.0 - sorry.
> otto
>>Thanks
>>Alejandro Hinojosa
>>Geology Department ,Earth Sciences Division
>>CICESE
>>Ensenada, Baja California, Mexico
>>Alejandro Hinojosa
