[GRASSLIST:8194] Re:libgrass_gmath.so error on startup (FC4)
Michele
michele.rocc at libero.it
Wed Sep 7 04:31:15 EDT 2005
>I've installed everything
> as root, and the owner and group of all the files is root.
If you use a normal user account maybe you can't work on data owned by root...
> The error message is:
> GRASS 6.0.1 (spearfish60):~/grass > Error in startup script: >ps.map:
> error while loading shared libraries:
> /usr/local/grass-6.0.1/lib/libgrass_gmath.so: cannot restore segment
> prot after reloc: Permission denied
> while executing
> "exec ps.map -p"
> (procedure "DmPrint::init" line 14)
> invoked from within
> "DmPrint::init"
> (procedure "main" line 32)
> invoked from within
> "main $argc $argv"
> (file "/usr/local/grass-6.0.1/etc/dm/d.m.tcl" line 894)
> Thanks for any help.
> -Chris.
____________________________________________________________
6X velocizzare la tua navigazione a 56k? 6X Web Accelerator di Libero!
Scaricalo su INTERNET GRATIS 6X http://www.libero.it
