[GRASSLIST:8216] Re: Making a raster coordinate a value
    Glynn Clements
    glynn at gclements.plus.com
    Thu Sep  8 13:10:48 EDT 2005
Joel Peter William Pitt wrote:
> What is the simplest way to get get a singular cell in a raster map to be
> set to a value,
> irregardless of the current regions resolution?
> More specifically I want to set closest cell to the origin (0,0) to have
> value 1. But only 1 cell must be present, and it must work for any
> resolution - although I'm currently concerned with working at res=1.
This is awkward if two or four cells are all an equal distance from
the origin. If you ignore that case, you're after the cell which is
less than half the grid resolution from the origin in each direction,
e.g.:
	out = abs(x()) < ewres()/2 && abs(y()) < nsres()/2
> I've been playing with mapcalc but the way it calculates x() and y() seems
> odd and round() rounds them to either 1 or -1, skipping 0. int() truncates
> leaving two rows/columns with a value 0.
round() rounds towards the nearest integer, so:
	round( 0.7) ==  1
	round( 0.2) ==  0
	round(-0.2) ==  0
	round(-0.7) == -1
etc.
int() rounds towards zero, so:
	int( 1.2) ==  1
	int( 0.9) ==  0
	int(-0.9) ==  0
	int(-1.2) == -1
