[GRASSLIST:8222] Re:Re: libgrass_gmath.so error on startup (FC4)
    Michele
    michele.rocc at libero.it
    Fri Sep  9 05:06:08 EDT 2005
> Michele:  libgrass_gmath.so is found in
> /usr/local/grass-6.0.1/lib/libgrass_gmath.so which is the install directory.
Well, add this line:
to this file:
/etc/ld.so.conf
(perhaps it's in a different directory in fedora...)
then run as root:
# ldconfig
it should work...
> It does seem kinda strange that C++ support is off by default.  Should
> that be turned on?
If you whant c++ support add:
--with-cxx
to your config string, if you don't enable some modules will not compile.
Michele.
