[GRASSLIST:8257] Re: legend of a vector map ?
Tue Sep 13 07:32:11 EDT 2005
> >>I need to create legend of a vector map.
> >>which command should I use ?
> >display monitor:
> >  d.vect.thematic
> >ps.map:
> >  vlegend command
> thank you
> d.vect.thematic looks absent.
> GRASS 6.0.1 (bartin):~ > d.vect.thematic
> bash: d.vect.thematic: command not found
It is new and only in the development version of GRASS (6.1-cvs).
You might be able to download the script from the CVS-web interface and
try running it, maybe it works with 6.0.1, maybe it doesn't. I've got a
feeling it doesn't.
Also you can try QGIS to load GRASS vectors & make nice vector legends.
Hamish
