[GRASSLIST:8260] Re: Installation errors
Giacomo Bertoldi
giacomo.bertoldi at ing.unitn.it
Tue Sep 13 11:52:08 EDT 2005
Thanks it works.
I did, as you suggested:
as root:
ln -s /usr/local/lib/libgdal.so.1 /usr/lib/libgdal.so.1
ln -s /usr/local/lib/libgproj.so.1 /usr/lib/libgproj.so.1
On 13 Sep 2005, at 1:24, Silvia Franceschi wrote:
> Hi Giacomo,
>> I've just installed on a DELL sever with Fedora the GRASS binaries for
>> Fedora Core 3, but GRASS is not working properly:
>> When it starts d.m I receive the following error:
>>> d.m&
>>> Error in startup script: ps.map: error while loading shared
>> libraries: libgdal.so.1: cannot open shared object file: No such file
>> or directory
>> while executing
>> "exec ps.map -p"
>> (procedure "DmPrint::init" line 14)
>> invoked from within
>> "DmPrint::init"
>> (procedure "main" line 32)
>> invoked from within
>> "main $argc $argv"
>> (file
>> "/usr/local/grass6.0.0-i686-pc-linux-gnu-14_03_2005/etc/dm/d.m.tcl"
>> line 894)
>> [1]+ Exit 1 d.m
>> Similar error with nviz
>>> nviz
>> nviz: error while loading shared libraries: libgdal.so.1: cannot open
>> shared object file: No such file or directory
>> Any solution?
> This error can be due to two problems:
> 1) you forgot to install gdal
> 2) fedora searches the gdal libraries where they aren't. There are
> several
> ways to solve this. You could search with:
> locate libgdal.so.1
> where the libs are on your system and link them to a folder where
> fedora for
> sure finds them.
> ex. libs is in /usr/local/lib and you link it to /usr/lib
> as root:
> Ciao,
> HydroloGIS :)
> PS: probably if the problem is the second, you will experience the
> same with
> the proj.
>> Thanks, Giacomo
>> Giacomo Bertoldi
>> Dept. of Civil and Environmental Engineering
>> Duke University
> _______________________________________________________________________
> _____
> HydroloGIS - Environmental Open Source Solutions
> Via Siemens, 19
> 39100 Bolzano
> www.hydrologis.com
> Silvia Franceschi
> tel: +390471068066
> mobile: +393384501332
> email: silvia.franceschi at hydrologis.com
> _____
Giacomo Bertoldi, Ph.D.
Duke University
E-MAIL: bertoldi at duke.edu
PHONE: +1 919 660 5559
