[GRASSLIST:8277] Re: r.sim and r,sim.sediment compilation problems
Dylan Beaudette
dylan at iici.no-ip.org
Wed Sep 14 12:43:33 EDT 2005
Helena,
Thanks for the ideas.
I have tried modifying the Makefile in the raster/ directory like this:
r.series \
+ simwe \
r.slope.aspect \
however, after a make clean && make i get this:
Errors in:
/home/dylan/src/CVS/grass6/raster/simwe
i have tried r.simwe, simwe and a couple other combinations, but with no
luck...
any further ideas?
thanks.
Dylan
On Wednesday 14 September 2005 08:18 am, Helena Mitasova wrote:
> Dylan Beaudette wrote:
> > Helena,
> > Thank you for taking time to reply to my email. I appreciate your taking
> > time to include the simwe modules in the CVS branch of grass.
> > One quick question, are these modules compiled and installed by default?
> > I tried updating my grass6-cvs repository, and re-compiling grass -
> > however i was not able to use the simwe modules.
> you might have figured this out already, but check the Makefile in
> /grass6/raster, if r.simwe is not there, you need to add it to get it
> compiled with the rest of raster modules. Let me know if you still have
> problems, I will have to go through some old emails to find out what
> needs to be done when you are compiling a module separately (you may be
> able to find it in the grass developers list archives too)
> Helena
> > here is my config thus far:
> > export CHOST="i686-pc-linux-gnu"
> > export CFLAGS="-march=pentium4 -O3 -pipe -fomit-frame-pointer"
> > export CXXFLAGS="-march=pentium4 -O3 -pipe -fomit-frame-pointer"
> > ./configure --with-tcltk-includes=/usr/include/tcl8.3 --without-postgres
> > --without-odbc --with-mysql --with-mysql-includes=/usr/include/mysql/
> > --with-freetype --with-freetype-includes=/usr/include/freetype2
> > --with-readline --with-cxx --enable-largefile
> > am i missing something ?
> > thanks,
> > Dylan
> > On Monday 05 September 2005 02:02 pm, Helena Mitasova wrote:
> >>Dylan,
> >>r.sim.water and r.sim.sediment should be now in GRASS61 CVS in
> >>grass6/raster/simwe
> >>At present it is most useful for getting spatial pattern for water flow
> >>and erosion deposition,
> >>It was designed for shallow water flow and I need to modify to code to
> >>handle erosion in areas with deeper
> >>flows correctly, although the pattern is pretty realistic, and there
> >>are many other things
> >>that need to be done to make it suitable for routine use. But it is a
> >>useful addition
> >>to the standard tools.
> >>Helena
> >>On Aug 22, 2005, at 1:10 PM, Dylan Beaudette wrote:
> >>>Hi,
> >>>Thank you for taking the time to respond to Markus about the questions
> >>>that I
> >>>had about r.sim etc.
> >>>My work deals with modeling soil genesis and morphology in rugged
> >>>terrain,
> >>>through the use of various landscape modeling techniques. I came
> >>>across the
> >>>paper you and Lubos Mitas published [1] and became instantly
> >>>interested in
> >>>implementing it with GRASS. I notived a couple references to the SIMWE
> >>>erosion model (r.simwe ?), as well as a reference to r.sim and
> >>>r.sim.sediment. Since my group is trying to quantitatively model soil
> >>>formation, a physically-based sediment transport model would be an
> >>>ideal
> >>>component for estimating areas of net loss or gain of sediment, as
> >>>well as
> >>>picking out colluvial vs. residual vs. alluvial systems. As I do most
> >>>all of
> >>>my work in GRASS, it would be ideal if r.sim /r.sim.sediment were
> >>>included in
> >>>the source tree. From your response to Markus, it seems that there may
> >>>still
> >>>be some work that needs to be done on these commands. If you have a
> >>>chance I
> >>>would be interested in hearing about the progress of these commands,
> >>>especially since I have yet to see such a process-based model
> >>>implemented in
> >>>soil science before.
> >>>Thanks for your time,
> >>>References:
> >>>1. Distributed soil erosion simulation for effective erosion
> >>>prevention.
> >>>Water Resources Research Vol. 34, No. 3, Pages 505-516, March 1998
> >>>Dylan
> >>>Dylan Beaudette
> >>>Soils and Biogeochemistry Graduate Group
> >>>University of California at Davis
> >>>530.754.7341
> >>Helena Mitasova
> >>Dept. of Marine, Earth and Atm. Sciences
> >>1125 Jordan Hall, NCSU Box 8208,
> >>Raleigh NC 27695
> >>http://skagit.meas.ncsu.edu/~helena/
Dylan Beaudette
530.754.7341
