[GRASSLIST:8285] Re: Init.sh problem GRASS5.3
Nagesh Bhatkar
bnagesh at nio.org
Thu Sep 15 00:33:19 EDT 2005
Paul Kelly wrote:
> On Wed, 14 Sep 2005, Nagesh Bhatkar wrote:
>> Then i copied the executable formed
>> ~/grass-5.3.0/dist.i686-pc-linux-gnu/etc/bin/inter/i.rectify
>> to my grass bin ~/grass53/bin
> That is your problem. It should go in the etc/bin/inter directory. All
> the files in bin/ are hard links to etc/front.end so it has been
> overwritten.
> If you copy etc/front.end over from your working installation that may
> fix the problem with it being overwritten, or perhaps re-run make
> install.
> Paul
Hello Paul,
Thanks a lot. The problem is solved. As u told me to do , after
recompiling, i copied the executable
~/grass-5.3.0/dist.i686-pc-linux-gnu/etc/bin/inter/i.rectify into my
~/grass53/etc/bin/inter directory
and everything works fine now.
Regards
Nagesh V Bhatkar
Project Assistant
Physical Oceanography Division
National Institute of Oceanography
India-Goa
Ph.no.: +91 0832 2450306 (Off)
: +91 0832 2461184 (Res)
Email : bnagesh at nio.org
nagesh_bhatkar at yahoo.com
