[GRASSLIST:8336] RE: db.execute syntax
Trevor Wiens
twiens at interbaun.com
Mon Sep 19 12:12:56 EDT 2005
On Mon, 19 Sep 2005 13:01:41 -0300
"Patton, Eric" <epatton at nrcan.gc.ca> wrote:
> Hmm...I gave that a try, with the following results:
> echo 'UPDATE Opil184a_ship_nav_med_smth SET MOD_60 = 1 WHERE CAT % 60 = 0'
> | db.execute
> dbmi: Protocol error (invalid table/column name or unsupported column type)
> ERROR: Error while executing: "UPDATE Opil184a_ship_nav_med_smth SET MOD_60
> db.describe shows that my cat and MOD_60 columns are indeed INT. So I'm not
> sure why there's a problem with the table column name/type.
> Perhaps quotation marks are needed somewhere?
> ~ Eric.
This is rather inane, but you do have the case correct? is is CAT not cat and MOD_60 not mod_60??
T
Trevor Wiens
The greatest obstacle to discovery is not ignorance - it is the illusion of knowledge.
(Daniel J. Boorstin)
