[GRASSLIST:8376] Re:Re: r.terraflow, or system, out of memory
Michele michele.rocc at libero.it
Thu Sep 22 04:53:59 EDT 2005
Thank you very much to you all,
I'll recompile with "--enable-largefile" and try it, and eventually dive in r.terraflow Makefiles.
Michele.
> So 10050 x 7760 cells * 80 bytes * 2 = ~12gb disk space needed, and as
> David mentions this is bigger than 2GB so you will need to have GRASS
> built with large file support*. If you did build GRASS with large file
> support, then this is a bug as the r.terraflow Makefiles aren't checking
> for that flag and making the needed adjustments. I'm pretty sure that
> this has not been fixed but don't know enough about LFS and the
> inner workings of the configure system to fix it myself.
> [*] ./configure --with-cxx --enable-largefile
> Hamish
