[GRASSLIST:8405] Re: using vector geometries
Hamish
hamish_nospam at yahoo.com
Sun Sep 25 20:52:11 EDT 2005
> Is it possible to use the geometry of an object to populate a column,
> on the fly or otherwise? If for example I want to get the area of a
> polygon or the bearing/direction of a line how could I access the
> geometry to do this?
v.to.db to store eg area in a column
also
v.build option=... to dump topology
bearing/direction of a line is hard as a "line" in GRASS is really an
"arc" or a series of vertices, not a single Point A -> Point B.
Hamish
