[GRASSLIST:8409] v.in.ogr
Dina Daresta dina.daresta at dyrecta.com
Mon Sep 26 04:09:42 EDT 2005
Dears,
launch the commando v.in.ogr, the following error generates me:
too many nested evaluations (infinite loop?)
    while executing
"ProgressBar::_modify .dialog0.progress"
    ("eval" body line 1)
    invoked from within
"eval ProgressBar::$cmd .dialog0.progress $args"
    (procedure ".dialog0.progress" line 1)
    invoked from within
"$opt($dlg,progress) _modify"
    (procedure "progress" line 7)
    invoked from within
"progress $dlg $val"
    invoked from within
"if [eof $fh] {
                close $fh
        } else {
                set str [gets $fh]
                append str "\n"
                if { [fblocked $fh] } { set str [read $fh] }
                while {[set idx [string f..."
    (procedure "prnout" line 5)
    invoked from within
"prnout 1 file8"
It means that the rows vector to load is too much large, or it can be
something that not going in grass6?
Thanks for the aid, Dina
