[GRASSLIST:8437] Re: "Large" file problem. Can do clipping with
arcview but not GRASS...
Craig Aumann
caumann at ualberta.ca
Tue Sep 27 11:36:43 EDT 2005
Thanks! I certainly appreciate all the work you do Radim and I posted
this more to find out if I was doing something stupid and if there were
work arounds. Thanks again!
On Tue, 2005-09-27 at 01:24, Radim Blazek wrote:
> I added Vect_set_release_support because the map is
> reopened in update mode. Should be better but probably still
> needs a lot of memory.
> Everything can be optimized but I don't have time to do everything.
> Radim
> On 9/26/05, Craig Aumann <caumann at ualberta.ca> wrote:
> > This is related to my earlier post 8400. To get around the problem of
> > importing the files, I simply used v.external. However, when I went to
> > do some overlays all of the overlays crashed as well:
> > On one file:
> > Breaking lines ...
> > Intersections: 832406 (line 888364)File size limit exceeded
> > And on another file:
> > Cleaning boundaries at nodes ...
> > Modifications: 8082
> > Breaking lines ...
> > Intersections: 1 (line 2955912)Unexpected error.
> > Aborted
> > GRASS 6.1.cvs (wavelets):~/DATA/ILM/scalingup/analysis/readin_setup >
> > What really upsets me is that I was able to do the overlays (clippings
> > actually) using ArcView's geoprocessing tool on these large files - each
> > one taking approximately 10-15 minutes on a Windows XP machine with only
> > 512 MB of memory!
> > The Linux machine has Grass60, has 1.5 Gig of memory and 2 gig of swap
> > space. I don't know the reasons here, but I'm having to eat crow for
> > not being able to handle these files with GRASS...
> > Cheers!
> > Craig
> > On Mon, 2005-09-26 at 01:16, Radim Blazek wrote:
> > > It can be that it consumes a lot of memory. Probably you have
> > > to add swap.
> > > Radim
> > > On 9/23/05, Craig Aumann <caumann at ualberta.ca> wrote:
> > > > I was reading a large shape file:
> > > > -rw-rw-r-- 1 caumann caumann 111771178 Apr 17 10:44 neforest.dbf
> > > > -rw-rw-r-- 1 caumann caumann 2355756 Apr 7 2003 neforest.sbn
> > > > -rw-rw-r-- 1 caumann caumann 119812 Apr 7 2003 neforest.sbx
> > > > -rw-rw-r-- 1 caumann caumann 746124196 Dec 10 2002 neforest.shp
> > > > -rw-rw-r-- 1 caumann caumann 1973924 Dec 10 2002 neforest.shx
> > > > and got the error:
> > > > ERROR: G_realloc: out of memory
> > > > Can v.in.ogr not handle this size of file?
> > > > Call and output are below
> > > > Cheers!
> > > > Craig
> > > > v.in.ogr -o dsn="$SHPDIR" \
> > > > output="$SHPFILE" layer="$SHPFILE" snap=1
> > > > Over-riding projection check.
> > > > Proceeding with import...
> > > > Layer: neforest
> > > > WARNING: 'user' in database definition is not supported, use db.login
> > > > Building topology ...
> > > > 259136 primitives registered
> > > > Building areas: 100%
> > > > 204742 areas built
> > > > 194638 isles built
> > > > Attaching islands: 100%
> > > > Attaching centroids: 100%
> > > > Topology was built.
> > > > Number of nodes : 226019
> > > > Number of primitives: 259136
> > > > Number of points : 0
> > > > Number of lines : 0
> > > > Number of boundaries: 259136
> > > > Number of centroids : 0
> > > > Number of areas : 204742
> > > > Number of isles : 194638
> > > > Number of incorrect boundaries : 63856
> > > > Number of areas without centroid : 204742
> > > > WARNING: Cleaning polygons, result is not guaranteed!
> > > > Topology was built.
> > > > Number of lines : 0
> > > > Number of areas : -
> > > > Number of isles : -
> > > > Snap boundaries (threshold = 1.000e+00):
> > > > Registering points ... 20377235ERROR: G_realloc: out of memory
