[GRASSLIST:8453] Re: New GRASS Module: v.drape
Radim Blazek radim.blazek at gmail.com
Thu Sep 29 03:44:46 EDT 2005
On 9/29/05, Dylan Beaudette <dylan at iici.no-ip.org> wrote:
> Also note that the syntax is
> v.drape [ -B | -C ] in=trails output=trails3d rast=elev_meters
> where the -B or -C refere to bilinear or cubic interpolation, default is
> nearest neighbor.
OK, it is better to use -b,-c (lower case) flags, it is standard in GRASS.
But probably the best would be an option
    method=[nearest|bilinear|cubic]
it is better  to use an option to select from 3 values.
Radim
