[GRASSLIST:8460] problem using pg.postgisdb
Luca luca.penasa at email.it
Fri Sep 30 14:50:38 EDT 2005
im using a debian gnu-linux system (a simply mepis). iv installed the
postgis package to use my postgre database lika a geographical DB, but
now i have some problems:
trying to use the pg.postgisdb command for crate a new geo-db the output is:
GRASS 6.0.0 (pat):~ > pg.postgisdb -c test -h redstar -U luca -p 5432
Create database. Expecting following settings:
libpostgis.so.x.x dir: '/usr/local/pgsql/lib/contrib/'
plpgsql.so file      : '/usr/local/pgsql/lib/plpgsql.so'
postgis.sql file     : '/postgis.sql'
CREATE DATABASE
ERROR:  could not access file "/usr/local/pgsql/lib/plpgsql.so": No such
fileor directory
ERROR:  function plpgsql_call_handler() does not exist
cat: /postgis.sql: No such file or directory
why this error?
Thanks...
Luca Penasa
 Email.it, the professional e-mail, gratis per te: http://www.email.it/f
 Sponsor:
 Audio, Video, HI-FI...oltre 2.000 prodotti di alta qualità a prezzi da sogno solo su Visualdream.it
 Clicca qui: http://adv.email.it/cgi-bin/foclick.cgi?mid=2955&d=30-9
