[GRASSLIST:568] Re: set up grass location
    Matthew Perry
    perrygeo at gmail.com
    Tue Apr  4 13:46:48 EDT 2006
If you have a dataset the is already in the projection you need, you
can import it with r.in.gdal/v.in.ogr with the "location=xxx"
parameter. This will automatically create location xxx according to
the datasets extents and projection info.
matt
On 4/4/06, Ana Soares <tiobrothercamarada at gmail.com> wrote:
> Hello :)
>  Is there any way to set up a new grass location (with all those fields :
> coordinate system, etc) without using the terminal ?
>  I mean, is there (and if there is, what is it) any structure where grass
> keeps this info so that I can enter it ? I know it uses environment
> variables, but I don't know
>  what to do for the fields like coordinate system, datum, etc
>  Help please :)
>  Thanks.
Matt Perry
http://www.perrygeo.net
