[GRASSLIST:583] Re:
lponti at infinito.it
Wed Apr 5 14:04:49 EDT 2006
Thanks David:
Your idea is something I had not thought to. The more I
use GRASS, the better I appreciate r.mapcalc.
Thanks again Stefano:
I looked at v.voronoi and it seems to get exactly the
buffer area I wanted. Voronoi polygons are also an
interesting geometric concept that I did not know about.
Luigi
On Tue, 4 Apr 2006 22:58:21 -0700
"David Finlayson" <david.p.finlayson at gmail.com> wrote:
> If white == 1 and black == 0 and you want all the
>"green" area
> half-way between the white point and the black point,
>why don't you
> try selecting all areas "green" >= 0.5?
> Step 1: interpolate raster
> Step 2: r.mapcalc "test = if(green >= 0.5, green,
>null())"
> Alternatively, you could buffer the white points by some
>reasonable
> distance and select for all cells within X meters of the
>white point.
> David
> On 4/4/06, lponti at infinito.it <lponti at infinito.it>
>wrote:
>> Dear list,
>> so far, I have been masking either via MASK or
>>r.mapcalc.
>> This way, only cells corresponding to MASK would display
>> in the masked raster.
>> In contrast, now I would like cells corresponding to a
>> "mask" NOT to display* in the main raster layer. Is
>>there
>> a way to do it?
>> This is part of a larger issue I am addressing and that
>>I
>> will briefly describe. In the attached sample image, you
>> see points imported via v.in.ascii and used to get the
>> green interpolated raster. Values at black points are
>> greater than zero, whereas the value of the white point
>>is
>> zero (and it is not used for interpolation since it has
>>no
>> biological meaning).
>> The end result would be to clip out a portion of the
>>green
>> raster around the white point. This portion would be
>> delimited by midpoints between the white point and the
>> closest neighboring black points.
>> So far, I have been trying to get a vector buffer around
>> the white point and then v.to.rast for some kind of
>> subsequent clipping (described above*). However I have
>>no
>> cue on how to get a comlex shape from neighboring points
>> as described. Is there a method already in place to do
>> this?
>> Many thanks in advance and any hints much appreciated,
>> Luigi
>> grass6/cygwin user
>> INFINITO ADSLFLAT 4 MEGA: SOLO 27,90 EURO AL MESE IVA
>>INCLUSA IP STATICO, BANDA GARANTITA 256Kbps ANTIVIRUS E
>>FIREWALL INCLUSI NEL PREZZO
>> http://adsl.infinito.it
> David Finlayson
INFINITO ADSLFLAT 4 MEGA: SOLO 27,90 EURO AL MESE IVA INCLUSA IP STATICO, BANDA GARANTITA 256Kbps ANTIVIRUS E FIREWALL INCLUSI NEL PREZZO
