[GRASSLIST:621] Re: gdal_translate --formats shows no GRASS support
Fri Apr 7 00:50:02 EDT 2006
[sorry for the late response]
> I Installed  gdal-grass-1.3.1.1.tar.gz
> gdal_translate --formats shows no GRASS support.
the GRASS plugin for GDAL must be installed in the correct dir, check
README file, etc that comes with it.
> Also installing gdal-grass-1.3.1.1.tar.gz  shows a
> different version(1.2.3) on using gdal_translate
> --version.
> I have only one gdal installed.
Apparently not.
> To debug i moved the gdal_translate  to
> gdal_translate.old and again installed
> gdal-grass-1.3.1.1.tar.gz . But again the
> gdal_translate created showed  version 1.2.3
> why is this happening?
>  gdal-config --version
>  1.3.1
>  gdal_translate --version
>  GDAL 1.2.3.0, released 2004/08/25
>   gdalinfo --version
>  gdal-config,gdal_translate and gdalinfo are in
> /usr/local/bin
try uninstalling as much as you can (does "make uninstall" work for gdal?)
then reinstalling.
note version number is probably taken from "libgdal.*" not what's in /bin/.
libgdal in both /usr/local/lib/ and /usr/lib/   ?
Hamish
