[GRASSLIST:640] overlapping polygons from bad shapefile
Dylan Beaudette dylan.beaudette at gmail.com
Sun Apr 9 21:57:16 EDT 2006
Greetings,
Received a geology map of our survey area in shapefile format, but some of the
polygons are overlapping. Upon import into grass with v.in.ogr, the
overalpping polygons are split according to the rules of topology at nodes (i
think).
Here is a link to the results of a quick `d.vect -c`
http://169.237.35.250/~dylan/temp/overlap.png
The red arrow points to an area where an underlying formation overlaps with
overlying Quaternary sediments -- rather common in reality, but difficult to
capture without overlapping polygons...
I am interested in classifying this map, and rasterizing the result. However,
v.to.rast does not quite produce the output that I would like in areas where
polygons are overlapping. i.e. v.to.rast is using the attribute from the
"lower" polygon where the two geologic unit polys are overlapping. Is there
anyway, short of manually removing these trouble polygons, to make v.to.rast
use the attributes associated with the "uppermost" overlapping polygon?
Any ideas would be appreciated!
Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
