[GRASSLIST:646] Re: running r.topmodel
Wouter Buytaert wouter.buytaert at tiscali.be
Mon Apr 10 11:42:23 EDT 2006
Hi Jaime and the rest of the list,
Just to say that I'm now one of the topmodel developers at Lancaster. We
are doing a major cleanup of the code and intend to release some new
versions soon, although in R rather than in GRASS (for several
reasons...) incorporating Monte Carlo and other stuff.
BTW, there is a bug in the r.topmodel infiltration module which Huidae Cho
fixed some weeks ago but probably didn't make it to the official version
yet.
Anyway, if you have more questions about topmodel, feel free to ask via
the list or directly to me.
cheers
wouter
On Thu, 30 Mar 2006, Thomas Adams wrote:
> Jaime,
> I believe I can help you, although:
> (1) I have never run TOPMODEL in GRASS (just the Fortran standalone version)
> (2) the link to Lancaster Univ. is old, in fact I'm not sure Kieth Bevan
> Lancaster Univ. even make the original source available now, from what I can
> see at: http://www.es.lancs.ac.uk/hfdg/freeware/hfdg_freeware_top.htm
> My guesses are these, since they conform to the GRASS r.topmodel manual page
> and the original files for the standalone version of TOPMODEL:
> parameters=3Dstring
> (i) TOPMODEL Parameters file, where the standalone file looked like this:
> SUBCATCHMENT 1
> 0.032 5.0 50. 3600.0 3600.0 0.05 0.0000328 0.002 0 1.0 0.02 0.1
> I can not remember what's what; I'll have to dig this up, plus I'll have to
> look at the r.topmodel source code more =97 I believe the data are read in this
> order from what I can see in the source=85
> input=3Dstring
> (i) Rainfall and potential evapotranspiration data file {probably a space
> delimited file with 2 columns}
> output=3Dstring
> (o) Output file {looks like flow is cu meters/timestep}
> Qobs=3Dstring
> (i) OPTIONAL Observed flow file {single column file}
> My recollection is that the inputs are in terms of meters/time-step (flow
> would be cu. meters/delta-t) =97 but I MUST CONFIRM THIS!
> The original input file in the standalone version combined the GRASS input
> Qobs files and looked like this:
> 950 1.0 <=3D=3D=3D=3D=3D=3D Number of timesteps & Number of hours per time step (I
> believe)
> .0000000 .0000619 .0000328
> .0000000 .0000647 .0000325
> .0010000 .0000619 .0000330
> .0010000 .0000560 .0000333
> .0010000 .0000457 .0000348
> .0005000 .0000323 .0000356
> .0005000 .0000156 .0000356
> .0000000 .0000000 .0000356
> .0005000 .0000000 .0000351
> Notice that the values are very small, which makes me believe that I think my
> guess about the units of the input are correct; this could be different in
> the GRASS r.topmodel code, of course. The columns are, respectively,
> precipitation, PE, and ObsQ.
> At least this can get you going. I'll try to get more on this in the
next few
> days. With a little help of some of the more experienced GRASS module=20
> contributors, I don't mind taking this on.
> Regards,
> Tom
> Jaime Carrera wrote:
>>  Hi,
>>  Has any one used the r.topmodel module? If so, I have the following
>>  questions:
>>  1) What are the instructions that are required in the "topmodel paramet=
ers
>>  file"?
>>  2) How should the topographic index statistics file be written?
>>  Cheers,
>>  Jaime
