[GRASSLIST:649] Re: running r.topmodel
Wouter Buytaert
wouter.buytaert at tiscali.be
Mon Apr 10 13:20:00 EDT 2006
Hi Tom,
Moving to R is a personal choice, rather than one of the group. But as
well, there's not one topmodel but a whole bunch of concepts, of which a
few happened to make it to the internet...
I chose R primarily for uncertainty analysis: in R it is very easy to pull
parameters from whatever probability distribution you want, construct a
parameter matrix and do a Monte Carlo run over the whole matrix.
Similarly, you can feed the modelling results directly to whatever
likelihood function that is available (or that can be programmed) in R.
As a result, it should be quite straightforward to use a GLUE approach
within this framework...
cheers
wouter
On Mon, 10 Apr 2006, Thomas Adams wrote:
> Wouter,
> That's excellent; the choice of going to R is pretty interesting. Does this
> mean the Glue algorithms will be ported there as well?
> Regards,
> Tom
> Wouter Buytaert wrote:
>> Hi Jaime and the rest of the list,
>> Just to say that I'm now one of the topmodel developers at Lancaster. We
>> are doing a major cleanup of the code and intend to release some new
>> versions soon, although in R rather than in GRASS (for several reasons...)
>> incorporating Monte Carlo and other stuff.
>> BTW, there is a bug in the r.topmodel infiltration module which Huidae Cho
>> fixed some weeks ago but probably didn't make it to the official version
>> yet.
>> Anyway, if you have more questions about topmodel, feel free to ask via
>> the list or directly to me.
>> cheers
>> wouter
>> On Thu, 30 Mar 2006, Thomas Adams wrote:
>> > Jaime,
>> > I believe I can help you, although:
>> > (1) I have never run TOPMODEL in GRASS (just the Fortran standalone
>> > version)
>> > (2) the link to Lancaster Univ. is old, in fact I'm not sure Kieth Bevan
>> > Lancaster Univ. even make the original source available now, from what I
>> > can
>> > see at: http://www.es.lancs.ac.uk/hfdg/freeware/hfdg_freeware_top.htm
>> > My guesses are these, since they conform to the GRASS r.topmodel manual
>> > page
>> > and the original files for the standalone version of TOPMODEL:
>> > parameters=3Dstring
>> > (i) TOPMODEL Parameters file, where the standalone file looked like
>> > this:
>> > SUBCATCHMENT 1
>> > 0.032 5.0 50. 3600.0 3600.0 0.05 0.0000328 0.002 0 1.0 0.02 0.1
>> > I can not remember what's what; I'll have to dig this up, plus I'll have
>> > to
>> > look at the r.topmodel source code more =97 I believe the data are read
>> > in this
>> > order from what I can see in the source=85
>> > input=3Dstring
>> > (i) Rainfall and potential evapotranspiration data file {probably a
>> > space
>> > delimited file with 2 columns}
>> > output=3Dstring
>> > (o) Output file {looks like flow is cu meters/timestep}
>> > Qobs=3Dstring
>> > (i) OPTIONAL Observed flow file {single column file}
>> > My recollection is that the inputs are in terms of meters/time-step
>> > (flow
>> > would be cu. meters/delta-t) =97 but I MUST CONFIRM THIS!
>> > The original input file in the standalone version combined the GRASS
>> > input
>> > Qobs files and looked like this:
>> > 950 1.0 <=3D=3D=3D=3D=3D=3D Number of timesteps & Number of hours per
>> > time step (I
>> > believe)
>> > .0000000 .0000619 .0000328
>> > .0000000 .0000647 .0000325
>> > .0010000 .0000619 .0000330
>> > .0010000 .0000560 .0000333
>> > .0010000 .0000457 .0000348
>> > .0005000 .0000323 .0000356
>> > .0005000 .0000156 .0000356
>> > .0000000 .0000000 .0000356
>> > .0005000 .0000000 .0000351
>> > Notice that the values are very small, which makes me believe that I
>> > think my
>> > guess about the units of the input are correct; this could be different
>> > in
>> > the GRASS r.topmodel code, of course. The columns are, respectively,
>> > precipitation, PE, and ObsQ.
>> > At least this can get you going. I'll try to get more on this in the
>> next few
>> > days. With a little help of some of the more experienced GRASS module=20
>> > contributors, I don't mind taking this on.
>> > Regards,
>> > Tom
>> > Jaime Carrera wrote:
>> > > Hi,
>> > > Has any one used the r.topmodel module? If so, I have the following
>> > > questions:
>> > > 1) What are the instructions that are required in the "topmodel
>> > > paramet=
>> ers
>> > > file"?
>> > > 2) How should the topographic index statistics file be written?
>> > > Cheers,
>> > > Jaime
> Thomas E Adams
> National Weather Service
> Ohio River Forecast Center
> 1901 South State Route 134
> Wilmington, OH 45177
> EMAIL: thomas.adams at noaa.gov
> VOICE: 937-383-0528
> FAX: 937-383-0033
