[GRASSLIST:667] Re: borehole database question
Patricio Antonio Toledo Peña
patricioantoniotoledo at gmail.com
Tue Apr 11 14:50:24 EDT 2006
> my only answer wuold be a script,
> - reading the answer of d.what.vect and set the point cat in a variable
> (ID=1)
> - run a query..... echo "SELECT * from logtable where id=$ID" | db.select
but, how do i connect the logtable if it is on a external server?
do i have to import it? do i have to connect it? how do i connect it, if
it has no geographic atributtes? should i have to put all the information
on a single table?
Patricio Toledo Peña
Dpto. de Geofísica - Universidad de Chile
Blanco Encalada 2002-Casilla 2777
Santiago-Chile
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060411/e1355552/attachment.html
