[GRASSLIST:684] QGIS/GRASS for Windows 060412
Radim Blazek radim.blazek at gmail.com
Wed Apr 12 10:08:18 EDT 2006
New build of QGIS/GRASS for Windows is available here:
http://mpa.itc.it/radim/wingrass/qgis-0.8.0-preview-win32-060412.zip
Fixed GRASS scripts. I was not able to get GRASS scripts working
if run from QProcess. It works if they are run from sh.exe
but if run from QProcess g.parser fails (without error)
to re-run script with execlp(). Because of this I emulate g.parser in
the plugin and scripts are run directly with variables set and
@ARGS_PARSED@ parameter.
Sören, can you try to run your testsuite?
Radim
