[GRASSLIST:736] Re: [GRASS5] postscript labels for vector objects
Lorenzo Moretti lorenzo.moretti at bologna.enea.it
Tue Apr 18 04:18:37 EDT 2006
Hi Michael
>IR17;ve just updated the GIS Manager in the cvs to add a new layer
>type for creating postscript labels for vector objects. It uses
>information from a labels file (created with v.label) to make this
>text. Because it creates TclTk text objects, it ignores v.label
>highlighting, background, and rotation options.
>Also, like the postscript text layer (renamed to clarify this),
>these labels can display on the screen or be output to a postscript
>device (eps, pdf, or printer). But they will not appear in raster
>ppm, jpeg, tif, or bmp output.
>I've also updated GIS Manager to conform with the new options
>database specifications, developed by Cedrick Shock. This will make
>formatting consistent across the entire gui and make it easy to
>change formatting across the entire gui.
>Michael
GREAT. This is a very useful command to insert text.
There is a problem when you make a PDF (or PS) from Print button.
This is an old problem in new gis.m.
- You create your vector - raster layers and text layers.
- You change the value inside the box more time (example text layers).
- At the end you save a PDF from Print button.
- This PDF displays any change you've made (only display the sequence
of changes): this is wrong because the file size is bigger and the
visualization is slow. This PDF have to contain only the true layers
not the history of changes. Try.
Bye
__________________________________________________________________________
||      Lorenzo Moretti        e-mail: lorenzo.moretti at bologna.enea.it
||/|/|  ENEA prot/idr          Web: http://wwwamb.bologna.enea.it/
||   |  via Don Fiammelli, 2   FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~  40128 BOLOGNA - ITALY  Ph: +39-0516098086  Fax: +39-0516098131
ENEA - Ente Nazionale per le Nuove Tecnologie, l'Energia e l'Ambiente
ENEA - The Italian Agency for New Technologies, Energy and the Environment
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060418/cf6463dc/attachment.html
