[GRASSLIST:751] Re: .ecw convert for GRASS
Stephan Holl
holl at gdf-hannover.de
Wed Apr 19 00:54:37 EDT 2006
Hello Miss Carla Meurk,
On Wed, 19 Apr 2006 14:57:18 +1000 Miss Carla Meurk
<s4112669 at student.uq.edu.au> wrote:
> Hi, can someone help me?
> I want to import a .ecw file into GRASS.
> Importing via GRASS (6.0.1) by: file > Import > Raster map > Multiple
> formats using GDAL
Since GRASS uses GDAL as the import-library GDAL needs to be compiled
against the ECW-libs. You can check if GDAL has ECW-support by using
gdalinfo --formats|grep -i ECW
> I get the error message
> r.in.gdal input = file name.ecw output = new file name
> ERROR 4: file name.ecw not recognised as a supported file format.
you GDAL-version does not suppport ECW-files. Depending on your
plattform you need to rebuild GDAL with ECW-support. See [1] for more
information.
> I would be very greatful for any help interpreting this error message
> I have tried the gdal-dev mailing list and even to convert files,
> using the gdal commands downloaded directly from their site, in my
> terminal window.
Best
Stephan
[1] http://www.gdal.org/frmt_ecw.html
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
