[GRASSLIST:772] Re: TIN Esri format
Wed Apr 19 19:40:32 EDT 2006
>> I'd like to know if is it possible to import a TIN layer product by
>Esri > ArcGIS.
> you could flip the TIN to a GRID and import it that way i presume
TIN is just a surface of joined nodes so it would probably be more
accurate to extract the node point data and reinterpolate using
something better, e.g. v.surf.rst or v.surf.idw.
Hamish
