[GRASSLIST:826] errors compiling 6.1.cvs xx04_22 (SUSE AMD 64 bit system)
Lars Forseth
l-forset at online.no
Sun Apr 23 17:19:19 EDT 2006
Hi
Has something happened in regard to the use of fftw in 6.1cvs? I'm getting
errors in trying to compile the two last weekly builds: Se these
errormessages:
" -lgrass_datetime -lz -lgrass_datetime -lgrass_gmath -L/usr/local/lib/
-lfftw -lm -lm -lz
/usr/local/grass-6.1.cvs_src_snapshot_2006_04_22/dist.x86_64-unknown-linux-gnu/lib/libgrass_gmath.so:
undefined reference to `fftw_plan_dft_2d'
undefined reference to `fftw_execute'
collect2: ld returned 1 exit status
make: ***
[/usr/local/grass-6.1.cvs_src_snapshot_2006_04_22/dist.x86_64-unknown-linux-gnu/bin/v.surf.rst]
Error 1
linus:/usr/local/grass-6.1.cvs_src_snapshot_2006_04_22/vector/v.surf.rst #"
I'm using these configure options:
./configure --enable-64bit --with-libs=/usr/lib64 --with-libs=/usr/local/bin/
--with-gdal=/usr/local/bin/gdal-config
--with-postgres-includes=/usr/include/pgsql --with-blas-libs=/usr/lib64
--with-lapack-libs=/usr/lib64 --with-odbc-libs=/usr/include/
--with-fftw-libs=/usr/local/lib/
Result:
GRASS is now configured for: x86_64-unknown-linux-gnu
Source directory: /usr/local/grass-6.1.cvs_src_snapshot_2006_04_22
Build directory: /usr/local/grass-6.1.cvs_src_snapshot_2006_04_22
Installation directory: /usr/local/grass-6.1.cvs
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -O2
C++ compiler:
FORTRAN compiler:
Building shared libraries: yes
64bit support: yes
NVIZ: yes
BLAS support: no
C++ support: no
DWG support: no
FFMPEG support: no
FFTW support: yes
FreeType support: no
GDAL support: yes
GLw support: no
JPEG support: yes
LAPACK support: no
Large File Support (LFS): no
Motif support: no
MySQL support: no
NLS support: no
ODBC support: no
OGR support: yes
OpenGL(R) support: yes
PNG support: yes
PostgreSQL support: yes
Readline support: no
SQLite support: no
Tcl/Tk support: yes
TIFF support: yes
X11 support: yes
fftw; 2.1.5
The errors happen if I try to configure without fftw also!
Regards
larsf
