[GRASSLIST:839] SV: Re: errors compiling 6.1.cvs xx04_22 (SUSE AMD 64 bit system)
Lars Forseth
lars.forseth at ntfk.no
Mon Apr 24 03:52:38 EDT 2006
hi!
(This is from my work adress)
No; I did'nt run make distclean - I'm thinking I should have done that; right?
I'll check config.log when home this evening!
Thanks
LarsF
-----Opprinnelig melding-----
Fra: owner-GRASSLIST at baylor.edu [mailto:owner-GRASSLIST at baylor.edu]På
vegne av Hamish
Sendt: 24. april 2006 07:59
Til: Lars Forseth
Kopi: grasslist at baylor.edu
Emne: [GRASSLIST:836] Re: errors compiling 6.1.cvs xx04_22 (SUSE AMD 64
bit system)
> Has something happened in regard to the use of fftw in 6.1cvs?
Yes, modified to now work with both FFTW versions 2.x and 3.x.
> I'm getting errors in trying to compile the two last weekly builds:
> linux-gnu/lib/libgrass_gmath.so: undefined reference to
> `fftw_plan_dft_2d'
did you run: make distclean
anything in config.log?
Hamish
