[GRASSLIST:855] Re: v.segment
Michael Barton michael.barton at asu.edu
Tue Apr 25 02:00:15 EDT 2006
Use v.category to attach categories.
V.to.db to add information to attribute table? I don't know if this works
with v.segment output or not. In fact, I can't figure out how v.segment
works either.
Create a dbf file using a spreadsheet (OO or Excel -- OO works better). Call
the first column "cat", make it an integer, and fill it with a sequence of
numbers equal to the number of points you have. Then use v.db.connect to
link them up.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Trevor Wiens <twiens at interbaun.com>
> Date: Mon, 24 Apr 2006 13:53:07 -0600
> To: GRASSLIST <grasslist at baylor.edu>
> Subject: [GRASSLIST:850] v.segment
> Is there an efficient way to create an attribute table for point file
> created with v.segment?
> T
> Trevor Wiens
> The significant problems that we face cannot be solved at the same
> level of thinking we were at when we created them.
> (Albert Einstein)
