[GRASSLIST:867] Re: New GRASS intro
Wolfgang wollez at gmx.net
Tue Apr 25 16:45:36 EDT 2006
and I still thought that the 6.1 is a beta and you are talking about a
6.2? I think what the most important thing is which has to be improved
for a beginner is the installation of grass. I'm running on cygwin and I
did not dare to try anything else which is provided by the cygwin
installer (at least that there is some version at all is a great help).
You are right, as a new user I had problems to understand what a
location/mapset is and how to create them. What me helped was a step by
step tutorial (sorry I'm only civil engineer who uses Grass for private
purposes).
I'm sometimes still confused that some commands need instead of "input"
a "map" at least this should be aliased.
An other thing I realized quite late is that many options are only
working when Grass is compiled with the right commands, but when you
have installed a binary version you hardly figure out which "plugins"
are working (mrsid in, ecw out, ...)
But I'm not thinking bad of Grass at all! I only takes a lot of effort
to get into it. Now I can handle some functionality like importing maps,
reprojecting maps, joining maps, using r.resamp and also exporting them
quite well. For getting so far having a step by step manual helped a lot
(and also the mailing list).
A final remark on the EPSG list. It seems that no all possibilities
(grids) are included and that (at least one) lacks the right false
northing. Also (when I under stand right) EPSG codes are available for
Datums and national meter grids (which need a datum).
If you need a beta tester who can "simulate" a new user, then you can
always ask me ;-)
Cheers
Wolfgang
Michael Barton schrieb:
> With the move toward releasing GRASS 6.2, it’s time we had a new intro
> to greet users starting GRASS.
> I’d hoped to make something really spiffy, easy for first time users to
> navigate without getting confused about GRASS jargon, but still quick
> for experienced users. Alas, I haven’t had the time to do all this
> before the impending 6.2 feature freeze, but I did manage to update
> things somewhat from the venerable, Spartan grey intro.
> I’ve rearranged the items on the intro screen to distinguish different
> functions, changed the descriptions to make it clearer that locations
> are for projections and mapsets are where a ‘GIS’ is stored, etc. I also
> added a new button to create a projection location from a georeferenced
> file (uses GDAL/OGR via g.proj). Finally, I added some color to the
> intro. No I didn’t make it green, but I did add a nice GRASS graphic.
> Many thanks to Markus who helped me get this committed to the cvs, where
> it now resides for your geospatial enjoyment.
> I think the next step would be to replace the g.setproj terminal screen
> for defining projections with a nicer GUI one based on g.proj. Another
> thing would be to add a search function to the excellent EPSG codes
> database.
> Cheers,
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
