[GRASSLIST:923] Re: Planning swath bathymetry surveys
Hamish
hamish_nospam at yahoo.com
Thu Apr 27 03:01:00 EDT 2006
> http://david.p.finlayson.googlepages.com/swathwidth
Ok, here you go.. working with a spearfish example:
g.region n=4926340 s=4921410 w=590010 e=592930 res=10
r.mapcalc bathy=elevation.10m-1250
r.colors bathy rule=terrain
v.in.ascii -n format=standard out=survey << EOF
L 2
591046 4924704
592377 4924468
EOF
#1.35km long
BEAM_MULT=3
DEM=bathy
LINE=survey
v.to.points input=$LINE output=temp_point dmax=100
d.rast $DEM
d.vect $LINE
d.stations temp_point #wiki add-ons
v.db.addcol map=temp_point layer=2 columns="elev double"
v.what.rast vect=temp_point rast=temp_swath layer=2 col=elev
v.buffer input=temp_point output=temp_circles type=point layer=2 \
bufcol=elev debug=buffer
# As stated before, "v.buffer bufcol=" is buggy in the cleaning step,
# which is why you get only center area as solid. So we do it manually:
# break polygons at intersections (flatten circles)
v.clean in=temp_circles out=temp_circles2 tool=break
# add centroids making areas
v.category in=temp_circles2 out=temp_circles3 step=0
# disolve common boundaries
v.extract -d type=area in=temp_circles3 out=temp_circles4
# (this works, maybe a clue as how to process bufcol data in v.buffer??)
# cleanup
g.rename v=temp_circles4,swath_area
g.mremove -f vect=temp_circles*
Done! One worm created.
proof: http://bambi.otago.ac.nz/hamish/grass/swath.png
# query area
d.what.vect -x
swath_area in user1 Area
Size - Sq Meters: 595889.059 Hectares: 59.589
Acres: 147.244 Sq Miles: 0.2301
# or
v.report swath_area op=area units=kilometers
|1|0.595889058998155
v.to.rast...
r.mapcalc MASK=...
r.univar ...
etc.
I really encourage you to try and get the v.mkgrid solution working, as the
results will be much more "real".
Hamish
