[GRASSLIST:955] Re: Error in Terraflow process
RAVI KUMAR ravivundavalli at yahoo.com
Fri Apr 28 03:03:40 EDT 2006
 Hi Nagraj,
  nice to C some Indian GRASS users.
  U must be using on GNU-Linux. Because the data input is very large
  increasing SWAP partition size might speedup the process.
  Pl Give details of
  Linux flavour, swap size.
  Otherwise terraflow works fine with smaller files.
  It will be nice If U can also say:
  What is your work area:
  Organisation:/ University
  How big is your team.
  Iam preparing a list of active indian grass users.
Iam V.Ravi Kumar, a Geologist from, G.S.I, Hyderabad.
  We are trying our best to promote grass which is Free and Open Source,
  and with all the tricks that the commercial software offer.
  Ravi
Nagaraj Thanushkodi <Nagaraj.Thanushkodi at rmsi.com> wrote:
Hi All,
I am trying to process 2GB Ascii raster in Terraflow module with GRASS
version 6.1.cvs.
But it showing following error.
"r.terraflow elev=newdata filled=fill direction=fdir swatershed=sws
accumulation=facc tci=tci d8cut=infinity memory=300 STREAM_DIR=/var/tmp
stats=stats.out -s
r.terraflow December 2003
region size is 19954 x 21199
cell newdata header compatible with region header
elevation stored as FLOAT (4B) WARNING: raster newdata is of type CELL_TYPE
--you should use r.terraflow.short
STREAM temporary files in /var/tmp (THESE INTERMEDIATE STREAMS WILL NOT BE
DELETED IN CASE OF ABNORMAL TERMINATION OF THE PROGRAM. TO SAVE SPACE
PLEASE DELETE THESE FILES MANUALLY!)
SFD (D8) flow direction
D8CUT= 999999986991104.000000
memory size: 300.00M (314572800) bytes
Memory manager registering memory in MM_WARN_ON_MEMORY_EXCEEDED mode.
reading data from newdata to stream /var/tmp/STREAM_n3rZJr:
total elements=423004846, nodata elements=153409740
largest temporary files:
FILL: 22.06G (23688271376) [423004846 elements, 56B each]
FLOW: 20.09G (21567608480) [269595106 elements, 80B each]
Will need at least 44.12G (47376542752) space available in /var/tmp
COMPUTING FLOW DIRECTIONS
classifying nodata (inner & boundary)
finding nodata
relabeling nodata
MM warning: limit=314572800B. allocating 157179492B. limit exceeded by
17734B.
17765B.
17796B.
17827B.
17858B.
17889B.
17920B.
17951B.
17982B.
18013B.
18044B.
MM warning: limit=314572800B. allocating 157117944B. limit exceeded by
24102B.
merging relabeled grid
MM warning: limit=314572800B. allocating 157138452B. limit exceeded by
17734B.
17765B.
17796B.
17827B.
17858B.
17889B.
17920B.
17951B.
17982B.
18013B.
18044B.
assigning preliminary directions
finding flat areas (plateaus and depressions)
plateau.cc:starting memscan
plateau.cc:memscan done
removing duplicate plateaus
MM warning: limit=314572800B. allocating 157138456B. limit exceeded by
17726B.
17757B.
17788B.
17819B.
17850B.
17881B.
relabeling plateaus
17718B.
17749B.
17780B.
17811B.
generating plateau statistics
MM warning: limit=314572800B. allocating 156974296B. limit exceeded by
17718B.
17749B.
17780B.
17811B.
assigning directions on plateaus
MM warning: limit=314572800B. allocating 157220512B. limit exceeded by
14518B.
14549B.
14580B.
14611B.
14642B.
14673B.
generating watersheds and watershed graph
creating windows
warning: using slower scan
r.terraflow: 3scan.h:163: void scan3line(FUN&, AMI_STREAM*,
AMI_STREAM*, AMI_STREAM*, BASETYPE, dimension_type) [with T =
waterGridType, BASETYPE = waterWindowBaseType, FUN = waterWindower]:
Assertion `ae == AMI_ERROR_END_OF_STREAM' failed.
Any one can help?
Regards
Nagaraj
Yahoo! Messenger with Voice. Make PC-to-Phone Calls to the US (and 30+ countries) for 2¢/min or less.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060428/04c2df32/attachment.html
