[GRASS-user] Problems with CVS compile part 2!
    Darrel Maddy
    Darrel.Maddy at newcastle.ac.uk
    Tue Aug  1 13:42:26 EDT 2006
Apologies but I now have a new problem (I am trying to compile the latest CVS on 64bit version of Ubuntu 6.06)
The ./configure throws up erros in
/home/ndm12/grass64cvs/grass61.cvs/lib/ogsf
/home/ndm12/grass64cvs/grass61.cvs/visualization/nviz
When I try the make file in ogsf I get the following:
..relocation R_X86_64_32 against `first_avcodec' can not be used when making a shared object; recompile with -fPIC
/usr/lib/libavcodec.a: could not read symbols: Bad value
collect2: ld returned 1 exit status
make: *** [/home/ndm12/grass64cvs/grass61.cvs/dist.x86_64-unknown-linux-gnu/lib/libgrass_ogsf.6.1.cvs.so] Error 1
Grass will run but not NVIZ (not a surprise I guess).
Is this a CVS problem or do I need to do something?
Once again help is appreciated.
For the record I abandoned RHEL (actually I trashed the install and cannot get it to reinstall!) and returned to Ubuntu which generally works out of the box.
Darrel
Prof Darrel Maddy
Chair of Quaternary Science
University of Newcastle
+44 191 2226440
Skype VOIP: ProfMaddy
