[GRASS-user] Problems with CVS compile part 2!
Darrel Maddy
Darrel.Maddy at newcastle.ac.uk
Tue Aug 1 18:28:44 EDT 2006
Hi Glynn,
Very many thanks, I now have a working copy :)
I can think of several possible solutions to this:
1. Use "./configure ... --without-ffmpeg ..."
This did not make any difference. The compile gave the same errors.
2. Remove $(FFMPEGLIB) from lib/ogsf/Makefile and add it to
visualization/nviz/src/Makefile instead.
This appear to have worked a treat! Just aswell as I would have had to
do some reading in order to perform the following:
3. Build libavcodec as a shared library.
4. Build libavcodec as a static library but compiled with the -fPIC
switch.
This is a very helpful list. Will I have to 'make' this change everytime
I update the CVS?
Hopefully most of my future questions will relate to the use of grass
and not its compilation.
Best wishes
Darrel
Prof Darrel Maddy
Chair of Quaternary Science
University of Newcastle, UK
http://www.ncl.ac.uk/geps/staff/profile/darrel.maddy
