[GRASS-user] Re: [GRASSLIST:1171] GRASS-commands and
sql-statements: wildcards not possible?
Markus Neteler
neteler at itc.it
Wed Aug 2 08:13:48 EDT 2006
wqual wrote on 08/02/2006 08:36 AM:
> Hi list,
> A short question on sql-commands in GRASS: is there a possibility to use
> wildcards in sql-statements? Using QGIS, I found out that the advance search
> function does allow statements like [coloum name] like 'Pattern%', but this
> does not work with GRASS. "*" also does not do the job...
> Best regards,
Wolfgang,
GRASS 6.1 supports wildcards (the DBF driver limited, the other drivers
like standard SQL):
http://grass.itc.it/pipermail/grass-dev/2006-July/024473.html
http://grass.itc.it/grass61/manuals/html61_user/sql.html
-> Example of pattern matching
cheers
Markus
PS: please use grassuser at grass.itc.it instead of the old
grasslist at baylor.edu
