[GRASS-user] Re: [Gdal-dev] Little experiment: comparison of vector projection OGR and ArcGIS
Dylan Beaudette dylan.beaudette at gmail.com
Wed Aug 2 16:49:29 EDT 2006
Hi Matt,
On Wednesday 02 August 2006 10:24, Matt Wilkie wrote:
> Hi Dylan,
> > A couple days ago I did another experiment, this time incorporating a
> > datum shift: GCS NAD83 --> UTM NAD27. I have summarized the results
> > here: http://casoilresource.lawr.ucdavis.edu/drupal/node/259
> > of note:
> > - the default tranform in ArcGIS does not produce the correct results.
> > - the 'NADCON' transform in ArcGIS produces the same results as OGR.
> I asked ESRI-L about this, and the near unanimous response is: there is
> no default transformation in ArcGIS, but an alphabetised list.
> "The 'default' transformation that Dylan refers to,
> NAD_1927_To_NAD_1983_6, is just the first in the alphabetical list. As
> it turns it out, it uses NTv2 and is designed for Quebec. ArcGIS
> generally doesn't set any default transformations but leaves it to you
> to decide which one is most appropriate. Dylan's data is outside the
> area covered by the NTv2 grid file, so essentially no tranformation
> occurs when he uses NAD_1927_To_NAD_1983_6. A better reference for him,
> which does list the methods, parameters and areas of use for the
> transformations is:
> http://support.esri.com/index.cfm?fa=knowledgebase.techarticles.articleShow
>&d=21327 "
> -- Melita Kennedy Product Specialist ESRI, Inc.
Ok. I didn't even notice that there was some order in the list. Then I stand
corrected, in that this was not a 'default' transform, just the 'first' one
in the list. Seems reasonable.
> Even if mistaken about the "default", thank you for conducting the
> experiment and telling us about it. Otherwise I would sailed along quite
> happily usiing the wrong selections myself. Also thanks to you we also
> know that provided the appropriate transformation method is chosen
> equivalent results can be achieved with both ArcGIS and GDAL, so we are
> all free to choose the tool most readily at hand.
> cheers,
Sure. Thanks for taking time to do some of the detective work. I have added a
small blub at the beginning of the original post, so that future visitors
will not have to pour over the comments to get at the final conclusions.
Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
