[GRASS-user] run commands sequentially - help please
Scott Mitchell smitch at mac.com
Thu Aug 3 13:48:20 EDT 2006
Actually, Tiago was the original poster, I just weighed in with some
code comments.
Scott
On 3-Aug-06, at 13:11, Slover, Kevin wrote:
> Scott,
>   I have actually done some Perl scripting that does this
> automatically… not sure if that would help, and it is very coarse
> Perl, but it gets the job done.  Example, I had about 500 ascii
> grids to import.  Created a script that would get the list of the
> files, create the command r.in.arc for each of these, and then a
> separate script (which I could combine into one) to mosaic the
> rasters together.  Actually, the Perl script created a shell script…
> Is this the thought that you were onto?
> Kevin Slover
> Coastal / GIS Specialist
> 2872 Woodcock Blvd Suite 230
> Atlanta GA 30341
> (P) 678-530-0022
> (F) 678-530-0044
> From: grassuser-bounces at grass.itc.it [mailto:grassuser-
> bounces at grass.itc.it] On Behalf Of Sampson, David
> Sent: Thursday, August 03, 2006 12:58 PM
> To: Scott Mitchell
> Cc: grassuser at grass.itc.it
> Subject: RE: [GRASS-user] run commands sequentially - help please
> Scott,
> Thanks for the cleanup... now it is not so dirty
> BTW I remember Markus showing us a way to save commands you type to
> the GRASS CLI into a script (think is was X.save where
> X=something).. this is good if you want to perform it once in
> geenral and then edit the script for variations. Couldn't find it
> off hand in the docs.
> I'd be interested to know if you could set and use variables in the
> approach we used bellow. I never tried.  but if you could say use
> output=$OUTMAP and input=$INMAP and then you can loop for a series
> of maps. and the input and output are auto generated based on the
> basefile name.
> Can someone provide a sample snippet of how this might look?
> Would the for loop be part of the said script, or would you call
> one script from another passing variables?
> This might be good if it is a repeated process you will use ALOT...
> a type of mild automation.
> I notice that in grass 6.1 there is lots of information in the
> OUTPUT window of what is passed from the command... can you capture
> this?.. I have not tried any of the icons....  if so then this is
> another way to maybe build your script.  I'm likin 6.1 more and more
> Just some thoughts.
> From: Scott Mitchell [mailto:smitch at mac.com]
> Sent: August 3, 2006 12:47
> To: Sampson, David
> Cc: Tiago Salgueiro; grassuser at grass.itc.it
> Subject: Re: [GRASS-user] run commands sequentially - help please
> A few elaborations that might help unix-newbies:
> On 3-Aug-06, at 12:25, Sampson, David wrote:
> Dirty approach,
> I used this approach when doing mass imports of files and only had
> slight variations.
> under linux (shoudl work too in cygwin, dos batch would achieve the
> same thing)
> I created a script file (executable text Basicaly) that for you
> would look like
> # for a script named runme.sh
> #(what ever header you need for your shell)
> #!/bin/sh
> Putting $!/bin/sh at the top of a script will ensure that the file
> gets interpreted by whatever the default shell is on the system.
> Forcing other shells is also possible here, but using just "sh"
> means you get the default (i.e. as opposed to bash, csh, tcsh, ksh,
> etc etc).
> v.in.asci (string of settings);
> note that should be ascii with two i's
> g.region (string of settings);
> v.surf.rst (string of settings);
> nviz (string of settings);
> #end of script
> then at the $prompt  you need to make the file executable
> $chmod 777 runme.sh
> Note this makes the file readable, writeable and executable to
> everyone on the system.  If this is just your own private linux or
> windows box, you probably don't care, but if someone is doing this
> on a multi-user system, you might not want other people to be able
> to edit your files.  Using chmod 755 would make it readable and
> executable to anyone, but only writeable to you, the owner of the
> file.  An alternative, more user-friendly syntax is
> chmod u+x runme.sh
> which simply says add the execute permission ("+x") for the User
> ("u") that owns runme.sh
> then at the $prompt inside a GRASS session you can run the file
> $./runme.sh
> boom!
> notice in the script that each line ends in a ; (semi-colon) this
> separates each command
> I don't think you need that.  It's C syntax to do that, not needed
> in a shell script unless you're concatenating multiple commands on
> to a single line.
> Note also that sometimes options need to be in quotes
> eg
> v.in.ascii option1="settings string that may contain escape
> characters or spaces";
> Alternatively you can capture what you enter at the CLI using
> bounces at grass.itc.it] On Behalf Of Tiago Salgueiro
> Sent: August 3, 2006 11:24
> To: grassuser at grass.itc.it
> Subject: [GRASS-user] run commands sequentially - help please
> Hi all,
> First of all you should know that I’m a beginner using GRASS.
> I want to create a 3D map from a text file with coordinates. I
> think the commands I will need are the following:
> 1 - v.in.ascii
> 2 - g.region
> 3 - v.surf.rst
> 4 – nviz
> But I don’t want to write the commands every time I want to see a
> map. So I desire to do this sequentially. How can I do that? This
> way I’ll only need to run one command and the map happens.
> Thanks for your help.
> Cumprimentos/Best Regards,
> Tiago Salgueiro
> grassuser mailing list
> http://grass.itc.it/mailman/listinfo/grassuser
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20060803/ec8f0ee8/attachment.html
