[GRASS-user] R.composite equivalent
Thu Aug 3 17:52:30 EDT 2006
Sampson, David wrote:
> Playing around with grass61 I notice there is no r.composite (as per the
> GRASS book)....
r.composite is present in all 6.x versions, and all of the later 5.x
versions. If it isn't present on your system, that suggests an error
in building GRASS.
There used to be a d.composite in the old 5.x versions; that has been
made obsolete by r.composite and d.rgb.
