[GRASS-user] v.in.ascii error: G_realloc
    Praktikant/in2 ARP
    praktikant.agi at bd.so.ch
    Fri Aug  4 07:30:45 EDT 2006
thanks Markus for your help. v.in.ascii is working fine now.
But now I have problems with the created vector file. I think because of the
missing topology.
If I want to use the created vector file for example with v.patch I get the
error:
Cannot open old vector dtm1107_32 at Solothurn on level 2
The same error if I use g.region vect=dtm1107_32
Another example: If I use v.surf.rst I get the error:
Vector is not 3D
Any suggestions how I can solve the problem?
Thanks
Michael
>Hi Michael,
>GRASS 6.1 can (probably) deal with such a number of points, but
>you have to add the '-b' flag to not build the topology. See
>http://grass.itc.it/grass61/manuals/html61_user/v.in.ascii.html
>Cheers
>Markus
>>On Fri, Aug 04, 2006 at 08:55:24AM +0100, Praktikant/in2 ARP wrote:
>> Hi everybody
>> I wanted to import a large ASCII File in Grass 6.0.2 (about 300MB and
about
>> 11.000.000 Points).
>> First everything was going fine but after some time i got the mistake:
>> ERROR: G_realloc: out of memory
>> What's going wrong?
>> Is it not possible to import such large files in Grass or is there a
maximum
>> size untill which v.in.ascii is working fine?
>> Thanks for your help
>> Michael
grassuser mailing list
grassuser at grass.itc.it
http://grass.itc.it/mailman/listinfo/grassuser
