[GRASS-user] Tutorial & help needed::join tables (which are stored
in postgres) and export result
Moritz Lennert
mlennert at club.worldonline.be
Fri Aug 4 08:04:43 EDT 2006
wqual wrote:
> Dear list,
> I am still testing, what kind of database I should use for my work with
> GRASS/QGIS. As my experiences with sqlite3 where not that positive (large
> datasets took very much time to be read into sqlite), I started working with
> postgres (and my first impression is that it's far more faster). dbf is
> quick, but does not offer me the possibility to perform "table-join", which I
> need every day.
> I am not that experienced with pg, therefore, I would like to ask you folks
> some questions about "daily GIS work with postgres in GRASS":
> * How can I join pg-tables in GRASS,
You don't have to do the work in GRASS (although you can use db.execute
to send any SQL-query you like to your database backend. If you prefer
to work with a graphical then you are free to do so.
BTW I find it easiest to just use views, instead of new tables, joining
two existing tables. That way you reduce the number of actual tables to
a strict minimum. And as a side-effect you don't erase a table when you
erase the map.
You can then use v.db.connect to connect the map to any table or view
you wish, as long as it has a column containing the category codes of
the map.
Just watch out: when you erase a map, the table it is linked to is also
erased.
> can I export a joined theme to make it
>> permanent (for example, I would like to create a shapefile out of it which
>> contains all information of the join)
When you use v.out.ogr to export a GRASS map to shape, it will create
the corresponding dbf file on the basis of the table/view linked to the
map. So, yes, you can.
> * Does anybody has experience with pg-frontends like knoda and pg_admin?
> Working with tables on the command-line is hard for people who used *other
> programmes* before ;)
Sorry, whenever I tried, I found going back to psql much faster...
> * what about large datasets: shapefiles with *qix-files seem to be loaded
> faster compared the same theme in GRASS with its attributes in postgres
What do you mean by 'loaded' ? How are you loading the shapefiles ?
> * tutorials available for this pg-stuff inside of GRASS?
Intros:
http://grass.itc.it/grass61/manuals/html61_user/databaseintro.html
http://grass.itc.it/grass61/manuals/html61_user/sql.html
Tutorial:
http://www.gdf-hannover.de/lit_html/grass60_v1.2_en/node49.html
Moritz
