[GRASS-user] R.composite equivalent
Sampson, David
dsampson at NRCan.gc.ca
Fri Aug 4 09:04:44 EDT 2006
Thanks.... I was looking for i.composite... But r.composite seems to be
what I wanted.
Cheers
-----Original Message-----
From: Glynn Clements [mailto:glynn at gclements.plus.com]
Sent: August 3, 2006 17:53
To: Sampson, David
Cc: grassuser at grass.itc.it
Subject: Re: [GRASS-user] R.composite equivalent
Sampson, David wrote:
> Playing around with grass61 I notice there is no r.composite (as per
> the GRASS book)....
r.composite is present in all 6.x versions, and all of the later 5.x
versions. If it isn't present on your system, that suggests an error in
building GRASS.
There used to be a d.composite in the old 5.x versions; that has been
made obsolete by r.composite and d.rgb.
